SAP 10.1
Published 10 October 2019
SAP 10.1 was published on 10 October 2019. It includes a grid carbon factor for electricity of just 136 grams CO2e/kWh. This is a dramatic fall from the 233 grams CO2e/kWh that was published in SAP 10.0 in July 2018.
This in turn is a dramatic fall from the 519 grams CO2e/kWh that was published in 2013 in SAP 2012.
These falls in the carbon factor of grid electricity reflect the transition from coal fired power stations towards carbon free electricity generation from wind, nuclear and solar.
A heat pump does not emit any CO2 as it transfers heat from the ground or the air into a building. It uses electricity to effect the transfer and this electricity may come from a carbon free source: zero carbon heating. If the heat pump uses grid electricity then it may cause CO2 to be emitted remotely by the National Grid.
grams CO2e / kWh
SAP 2012
October 2013
SAP 10.0
July 2018
SAP 10.1
October 2019
Heating oil 298 298 298
Mains gas 216 210 210
Electricity 519 233 136
The following table shows the grams of CO2e emitted per kWh of heat delivered assuming grid electricity is used by a ground source heat pump with a coefficient of performance of 4:
grams CO2e / kWh of heat
SAP 2012
October 2013
SAP 10.0
July 2018
SAP 10.1
October 2019
Electricity 130  58  34
The CO2e emitted per kWh of heat delivered by a heat pump using grid electricity is now only a fraction of the CO2e emitted by a combustion boiler, and even this will fall as the grid decarbonises further.
The implications of adopting SAP 10.1
There are two important implications of the reduction in the grid carbon factor for electricity by 74% compared to the SAP 2012 figure for planning permission purposes:
  • The first is that the carbon emissions from electric heating will now reflect the current reality, instead of being many years out of date.
  • The second is that technologies generating electricity, such as gas-engine CHP and PV, will only be credited with reducing carbon by the amount of current grid carbon electricity, instead of the historic figure used in SAP 2012.
These long awaited steps are a major improvement in encouraging the transition toward low carbon heating, as is the new consultation on the Future Homes Standard.
Transition toward low carbon heating
The transition toward low carbon heating implies a transition toward the electrification of heat and installing heat pumps.
An alternative route has been proposed to pipe hydrogen through the existing gas grid. While burning hydrogen in air would lead to lower emissions of CO2, it would also emit up to six times as much NOx as burning natural gas in air.
NOx from gas boilers already contributes to 22% of the NOx in London and this contributes to respiratory diseases and up to 9,500 deaths a year in London alone.
Heat pumps do not employ combustion and therefore do not emit any gases at all where they are used. They can contribute to the Clean Air Strategy as well as the Clean Growth Strategy.
      Ground Source Heat Pump Association logo      ICAX is a member of BSRIA      Electrify Heat
