Heat Sharing District Networks
Innovate UK encourages innovations in integrated energy supply chains - Feasibility Study
Innovate UK is running a competition to invest up to £9.5 million in innovations to encourage cross-sector supply chains that will deliver integrated energy solutions at different scales to meet the many energy systems challenges of achieving a low-carbon economy by 2050.
The DECC has the goal of seeing 15-25% of the UK’s growing space and water heating demand delivered through heat networks, in place of the current 2% capacity.
Developing scalable solutions to networks is critical to meeting heat demand, and to reaching the UK’s 2050 carbon reduction targets. Developing heat network infrastructure is both a technical and social challenge due to the high infrastructure costs, and the diverse actors and supply chains involved.
ICAX™ wins Innovate UK Award with LSBU to demonstrate Heat Sharing Networks™
Innovate UK has awarded a contract to ICAX and London South Bank University to provide a feasibility study on Cold Water Heat Networks.
Cold Water Heat Networks are designed to provide a more cost effective, flexible, and scalable alternative to conventional district heating network technology. Cold Water Heat Networks transfer warmth via an underground piping circuit between buildings at near ground temperature and extract it via heat pumps in each building.
This radical innovation will allow the integration of diverse energy systems through the recovery of low grade waste heat, delivery of simultaneous heating and cooling, links to heat storage in boreholes and provides lower installation costs by making use of existing infrastructure, none of which are possible with conventional high temperature heat networks.
Cold Water Heat Networks Demonstration at LSBU
The CWHN project is a collaboration between ICAX Ltd and LSBU, in which ICAX provides the technical and industry expertise, and LSBU provides the research expertise and the platform from which to disseminate project results. ICAX Ltd is an innovation leader in cleantech energy for heating and cooling, with a patent for Interseasonal heat storage and considerable experience in heat networks projects.
This proposal will outline the research packages through which this project will demonstrate that Cold Water Heat Networks represent a scalable and adaptable answer to meeting the UK’s growing demand for efficient space and hot water heating.
The Intranet of Heat
This new heat infrastructure is the birth of an "Intranet of Heat". The Intranet of Heat enables the exchange of information about sources and needs of heat – and cooling – and then allows heat exchange from those buildings with surplus heat to those in need of heat.
CEREB
ICAX
