Carbon Emissions Calculator for heat pumps using Grid Electricity
The current carbon emissions from different heating systems are shown below in a small program that updates to the current grid carbon intensity every half hour.
The carbon emissions of heating based on heat transfer using grid electricity are dramatically lower than any heating system based on combustion of carbon compounds.
The route to lower CO2 emissions from heating
If we are serious about controlling carbon emissions, we need to stop combustion of carbon fuels and move towards the electrification of heat.
That means installing ground source heat pumps now.
Not just for off-gas grid areas, but for all on-electric grid areas as well.
Not just for heating, but also for cooling as well.
The route to lower NO2 emissions from heating
In addition to CO2 emissions, combustion releases NO2 emissions. NO2 emissions have been identified, along with particulates, as the key factors in urban air pollution. Air pollution is now thought to be contributing to up to 9,500 premature deaths a year in London alone.
Carbon Emissions Calculator for heat pumps in parts of the UK
The table above shows carbon emissions from different heating systems across the UK on average. To see the carbon emissions in each of the different countries, or parts of the UK, then click on the relevant red label on the right.
Scotland is generally the country in the UK generally which has the lowest Grid Carbon Factor, and the South of Scotland generally has the lowest Grid Factor within Scotland.
Ground Source Heat Pump Association
