Commercial Ground Source Heat Pump Installations by ICAX Ltd
ICAX has installed a number of large scale ground source heat pumps as part of its installations of Interseasonal Heat Transfer incorporating solar recharge. A ground source heat pump is a key component in Heat Delivery in transferring heat from the ground into a building. The other critical components in Interseasonal Heat Transfer are Heat Capture and Heat Storage because if you plan to extract heat from the ground in winter without any mechanism for replacing the heat taken in summer you risk installing an unsustainable system: as you extract heat from the ground it gets colder – and less efficient at providing heating.
The effective use of Renewable Heat for commercial buildings requires three keys steps:
- Capture of heat
- Storage of heat
- Release of heat
Capture of Renewable Heat
The most direct form of renewable heat capture is to collect the energy beamed down from the sun each day. All other forms of renewable heat involve the use of indirect solar heat that has been captured earlier from the power of the sun through photosynthesis, wind power or wave power. Heat can be captured directly by using roof top solar thermal panels [flat plate collectors or evacuated tubes] or through ICAX Asphalt Solar Collectors, which are designed to collect large amounts of warmth at a lower overall cost.
Storage of Renewable Heat – Solar Recharge
It is difficult to store heat energy, just as it is difficult to store electricity efficiently or cheaply. Hot water can, however, be stored effectively in insulated tanks on a small scale for a short period to bridge the time when solar heat is captured in the day to the time when heat may be needed at night for washing.
Storage of heat for an extended period has been problematic, until the recent breakthrough by ICAX which has, after an extensive period of studying the movement of heat in the ground, designed and patented Thermal Banks.
ThermalBanks are very large heat stores, normally constructed beneath the foundation of new buildings. They are designed to store a large amount of warmth over a period of months, between seasons.
This breakthrough allows solar heat to be freely stored in summer, when it is surplus, until the time that it is needed for space heating in winter. Solar collectors are used to raise the temperature of the Thermal Bank in the ground from its natural temperature of 10°C to nearly 30°C over the course of the summer months.
Release of Renewable Heat
There are no technical problems in the release of hot water from insulated tanks for washing.
There are issues with the release of warmth from ThermalBanks for space heating in winter. However, these are neatly solved by using ground source heat pumps to deliver heat via underfloor heating.
A ground source heat pump is usually linked to the ground by pipe work from which it can extract a ground temperature of 10°C. It uses electricity in a compression cycle to raise the temperature of water by 30°C to the 40°C, which can then be used for underfloor heating.
Commercial Heating and Cooling Systems – Interseasonal Heat Transfer
A heat pump in an Interseasonal Heat Transfer system is very similar except that the heat pump starts with a temperature of 25°C from the Thermal Bank, instead of just 10°C from the ground. The heat pump is twice as efficient because it has half as much work to do to raise the temperature of the water to the 40°C that is needed for underfloor heating.
Recycled Heat for Solar Heating
Interseasonal Heat Transfer from ICAX is, therefore, a new form of Recycled Heat that combines the advantages of Solar Thermal energy capture, with heat storage in Thermal Banks. This allows a heat pump to tap into stored summer sunshine in winter and double the coefficient of performance (CoP) of heat pumps: On Site Renewable Heat.
Renewable Cooling
There is a further exciting aspect of Interseasonal Heat Transfer. Having installed IHT in a new building to provide Renewable Heat in winter all the mechanism is in place for the IHT system to work in reverse and provide Renewable Cooling in summer, at a fraction of the annual running cost of using air conditioning and chillers to provide cooling. The additional capital cost of tuning underfloor piping to provide cooling, as well as heating, is marginal: however, there are further benefits in that the closer spacing of pipes enables heating to be provided at a lower delivery temperature – and a higher co-efficient of performance.
Integration and Harmony – Ground Source Heating and Cooling
IHT is a straightforward system that is designed to balance the heating and cooling requirement of a building over the course of the seasons. This is in contrast to the traditional approach of throwing money and fossil fuels indiscriminately at both extremes of the year, as if they were separate problems that had to be addressed by separate budgets and separate mechanisms.
Cost of ground source heat pump installation
The cost of a ground source heat pump systems will be more than the capital cost of a gas boiler systems. However, the running cost will be much less than a gas system, even before receiving the Renewable Heat Incentive. The capital cost of a ground source system that provides both heating in winter and cooling in summer compares favourably with the cost of providing a gas heating system for winter and a standard air conditioning system for cooling in summer. This is particularly true for a new building which may have to pay to install a new gas supply.
Invisible Heating System
A ground source heating system is an invisible heating system: no planning permission is required.
Ground Source Heat Pump Problems
Ground source heat pump installations may not work successfully if they are not designed by someone with a good understanding of the characteristics of the building, its use and the local geology. The designer needs to know the expected heating loads and cooling loads of the building and the nature of local ground conditions. He should perform a full thermal modelling exercise on the installation in order to calculate the energy flows to and from the thermal bank over each annual cycle and determine the optimium size for the ground loops. If there is no mechanism for recharging the ground in summer then the ground loop will need to be larger (and more expensive) and the sustainability of the system may not last the course over the life of the system.
The installer should also be employed for operation and maintenance in the first years of use to ensure that the owner is getting the best use of the system. The installation should be tuned to the way the building is being operated in practice. This may vary from the specification given to the designer when the building was planned. You need to plan for a Soft Landing.
See also: Ground Source Heat Pump Costs
See also: How Ground Source Heat Pumps Work
See also: Ground Source Heating and Cooling
